Farmall A rear end lube
Posted by Chad from Michigan on February 15, 2007 at 12:23:29 from (152.72.151.71):
I had to drain the rear end and pto of my Farmall "A" Is it out to put 90wt gear lube in it?
Or what is prefered? I put the Case Ih stuff in my cub hytran? and it leaked all the time.
Yes it was to the right level I pulled the plug and filled it till it came out the hole same as on the "A" is it ok to use 90wt?
