Re: Farmall A rear end lube
Posted by Dave BN on February 15, 2007 at 15:50:09 from (64.12.116.71):
In Reply to: Farmall A rear end lube posted by Chad from Michigan on February 15, 2007 at 12:23:29:
Yes, 80W/90. You should change the fluid in the final drives also. You need to remove the pans at the bottom of each final drive to drain the old fluid. Refill thru the plug in the cast housing just above the pan. Use the same fluid as in the tranny. You should need two gallons to do the whole job. You will need new gaskets to put the final drive pans back on. Dave.
