farmal 450
Posted by DARYLE on February 15, 2007 at 19:30:22 from (71.1.100.138):
I have a farmal 450 on propane. When I turn the vapor valve on to start it, it goes right on through the regulator and carborator and out the air filter. It's an Ensign Regulator and Carberator. I have replaced the diaphrame in the regulator and still doing it. On Vapor or Liquid either way.
