Re: farmal 450
Posted by Owen Aaland on February 15, 2007 at 19:45:52 from (65.165.246.11):
In Reply to: farmal 450 posted by DARYLE on February 15, 2007 at 19:30:22:
The regulator is still leaking. Fuel, either liquid
or vapor, must not pass through the regulator
until a slight vacuum is applied to the outlet
port.
