Re: Fuel filter change help on D-239 motor
Posted by Wiill on February 16, 2007 at 00:04:14 from (209.112.151.205):
In Reply to: Fuel filter change help on D-239 motor posted by IH250A on February 09, 2007 at 17:33:17:
Hello. I also have an IH 250A with a D239. Both fuel filters are the same. The WIX 33166 filter crosses over to a NAPA Gold 3166. You can also get air, oil, and the hydrolic filter at NAPA. If you have the hydrostatic transmission you can get the two filters for it through a Case dealer. I have all the part numbers if you need them. As the other folks have told you, there is a bleeder plug on top of the dual fuel filter housing. That will probably be all you need to bleed if it was running just before you shut it off to change the filters. But it is possible that you will have to bleed the inlet fuel line where it connects into the fuel pump. If you have to do that you will probably also need to crack the fuel lines at the injectors and crank the engine until it sputters before you tighten them back up. You mentioned the temps were pretty cold...if you are using #2 diesel I wonder if you are having a jelling problem? I live in Alaska and have to use #1 diesel during the winter months. I start seeing jelling with #2 diesel at temps somewhere around -15 (wind chill doesn't matter). If you do use #1 diesel you should also add some lubricant to the fuel so it will be a little easier on the injectors. I use my tractor for snow removal at temps down to about 25 below. When it's colder than that I don't like to run it.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
