Re: battery not keeping charge
Posted by gene bender on February 16, 2007 at 05:17:40 from (67.55.226.214):
In Reply to: battery not keeping charge posted by Farmall 200 NE on February 15, 2007 at 15:46:24:
I would unhook the battery take a reading with a hyd then charge and see if the hyd reading will show the 1260 or so on the hydrometer after charging. Let it set unhooked to see if the reading stays then when hooking the batt up check for a spark when last connection is made. Now you dont know if you have a bad charging system or a bad battery.
