Re: Help with paint and primer for my 41 a
Posted by GordoSD on February 16, 2007 at 06:43:26 from (66.115.200.140):
In Reply to: Help with paint and primer for my 41 a posted by 1941 farmall a boy on February 16, 2007 at 01:31:12:
It's my opinion that the grill, hood and gas tank should be as close to flawless as possible. To get them really straight and dent and rust free you need to:
Sandblast them. Don't worry, that steel is 10 times thicker than autos and won/t be damaged.
IMMEDIATELY after blasting prime with epoxy primer.Now they are sealed against all moisture.
Then use basic auto primer surfacer, sanding between double/triple coats to get a perfect surface for painting.
The IH 2150 with hardener can produce a beautiful finish if properly applied with a quality finish gun.
Gordo
