Re: 1962 International 240 Utility Tractor - 3 pt
Posted by Jeff311 on February 16, 2007 at 19:06:03 from (205.188.116.133):
In Reply to: 1962 International 240 Utility Tractor - 3 pt Hitc posted by Stancer on February 15, 2007 at 19:18:08:
Factory 3pt is indeed a hard item to find for a 240. IH also made a Factory 2 pt Fast Hitch and Factory 3pt Fast hitch to go along with the 3pt hitch. The 3pt Fast hitch is completely different from the regular 3pt. The 3pt Fast hitch mounts on the same bail assembly as the 2 pt hitch.
You might consider adding a 2pt hitch and getting some slide in balls on points to convert it to a 3 pt. I would have a complete 2pt FH with a 3pt toplink mount or 3pt FH but no toplink for the 3pt FH. It takes a special top link. You are still looking at $4-500 for the complete 2pt unit without adding valves and quadrant assembly. Valves and quadrant would be another $200.
Jeff
