Re: HELP !! 300 UTILITY
Posted by Wardner on February 17, 2007 at 16:48:19 from (4.154.240.9):
In Reply to: HELP !! 300 UTILITY posted by tom nj on February 17, 2007 at 15:52:02:
Tom, you just can't plug an IPTO into any ole tractor even if similar tractors have the IPTO.
The IPTO gets its power from the splines of the engine clutch pressure plate; not the clutch disc. That power flows though a sleeve and gear which mesh with another shaft and gear below it. That shaft runs through the hollow center of the transmission countershaft. If you have all that stuff, you can think about installing the IPTO.
Right now all you can do is install what is called a transmission type PTO. It stops when the clutch is disengaged. It couples to a solid countershaft. You can retrofit all the IPTO parts if you wish, but I think you would be better off trading tractors. It all depends on what you have for equipment, time, and money for the parts.
As for Jay, don't knock it until you have tried it.
