Re: M FARMALL CAMSHAFT
Posted by RustyFarmall on June 22, 2007 at 13:37:26 from (66.43.253.26):
In Reply to: M FARMALL CAMSHAFT posted by CHIEFEAVES on June 22, 2007 at 13:27:03:
You've already spent some pretty good money. Get the most bang for your buck by purchasing a brand new camshaft. Camshafts do wear out, and when that happens the valves will not open as far as they should and performance will suffer.
