Re: 560 diesel hydrualic problems again
Posted by billde on June 23, 2007 at 18:31:49 from (66.249.52.188):
In Reply to: Re: 560 diesel hydrualic problems again posted by alex ahlbrecht on June 23, 2007 at 17:35:20:
On mine the 2pt is connected to the left valve under the dash via a steel line to a junction block under the seat and then rubber down to the lift cylinder.
If you are using the fast hitch drawbar to run a baler, lock the drawbar, otherwise you could damage the pto shaft.
