Farmall MD stuck starter valve
Posted by lekwyo on June 23, 2007 at 21:12:53 from (209.193.64.37):
Posted a message earlier about a possible stuck starter valve on an MD. I did a compression test on the gas side, figuring that when the starting lever is in the diesel position, there should be no compression registering thru the the spark plug hole. All cylinders showed no leak except for # 1 which showed 120 psi. Tonight pulled the valve cover off and the #1 starter valve is indeed stuck open. Is there any way to free the valve without pulling the rocker arm assembly? The starter valve has a cover over it which makes it impossible to put ATF or PB blaster directly on the valve stem. Worse yet will I have to pull the head off to fix this problem? Any previous experience or suggestions greatly appreciated.
Thanks
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
