Re: M gear box fluid
Posted by Janicholson on June 24, 2007 at 05:11:15 from (66.173.50.68):
In Reply to: M gear box fluid posted by Carden on June 24, 2007 at 04:52:00:
The Bolt at the bottom of the brake housing is a support adjuster for the brake band inside the tin housing. It supports the brake band and is not tight when correct. The plug to check the trans is on the clutch side in front of the brake housing. JimN
