Re: Red Power show
Posted by John M on June 24, 2007 at 16:42:58 from (204.116.130.100):
In Reply to: Re: Red Power show posted by Farmall Md nut on June 24, 2007 at 15:03:21:
Thats the generic replacment manifold. It can be used with Kerosene, nut you havbe to adjust the flapper at the manifold instead of with the rod. Thats the same one I have. Thats why you see so many with the hoods cut. The factory pipe wont work right, or so Im told, and most of the time the hood ws cut instead of a new pipe being made.
