Changing Farmall H clutch
Posted by jhb on June 26, 2007 at 13:11:21 from (75.167.253.119):
First time for changing a Farmall H clutch questio: Should a person use a shortened pilot shaft to allign the friction disk when installing a new clutch or can the regular shaft be used conveniently to do the job? Any knowledgeable advanced information will be appreciated. It helps if I have advanced info before starting a project. Thanks in advance.
