Re: H rear end update HELP!!!
Posted by Bob Kerr on June 26, 2007 at 17:46:56 from (152.163.100.197):
In Reply to: Re: H rear end update HELP!!! posted by williamf on June 26, 2007 at 14:21:54:
Yes, It whines when it is in neutral and the clutch is out. it stops when clutch goes down. It does it in every gear and gets louder when going up a grade. It also whines when going fast and pushing the clutch in. It almost sounds like a super bad power steering pump with little fluid in it. I do think it is that lower gear. Another thing the coupler ring had some wear on the holes and the bolts are worn also, so the clutch shaft is a bit wobbly. I am ordering new stuff for that tomorrow morn. I guess I will check on that lower gear while I am at it.
