Re: Farmall A - speed surging
Posted by georgeky on June 28, 2007 at 07:51:28 from (205.188.116.73):
In Reply to: Farmall A - speed surging posted by Tom R. S. on June 28, 2007 at 07:01:21:
The best remedy is to get you a good service manual which will have all the governor adjustments in it. On the bottom of the governor unit there is a cap and lock nut. This is the surge bumper that controls that. It will need to be turned in a little and should cure this. Do not turn it in to much as it will interfere with your low idle speed. Get the book. I&T No IH-8
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
