Re: 706 has steer-to-the-right problem
Posted by ChrisAS on June 28, 2007 at 08:07:07 from (71.34.207.104):
In Reply to: 706 has steer-to-the-right problem posted by AES on June 28, 2007 at 06:02:28:
Could be steering behinf left battery, could be tooth on rack in the front bloster could be the hand pump at steering wheel. The hand pump should slip a little if you hold it at the end of steering, so if it stops to the right at center could be hand pump, if a little slipage at sent I would else ware first. Jack up front end and see if you can turn wheels with a bar, that will tell you if rack is ok.
