Re: 706 has steer-to-the-right problem
Posted by Walter Thompson on June 28, 2007 at 09:01:48 from (70.248.132.75):
In Reply to: 706 has steer-to-the-right problem posted by AES on June 28, 2007 at 06:02:28:
Will it turn easier that way when going in reverse? Sometimes the thrust bearing on vertical shaft that the axle is attached to (whatever that is called) gets dry and gets rough making it hard to turn in one direction. In your case it would be the left side that is having the problem. hth WaltMo
