Re: Cub PTO disengaging question
Posted by Janicholson on June 28, 2007 at 14:29:46 from (66.173.50.83):
In Reply to: Cub PTO disengaging question posted by AlexLV on June 28, 2007 at 11:28:31:
If it is not under load at all (no load on PTO) it is OK. If loaded at all it will wear the teeth on the dog clutch that controlls off and on. The repair is not nearly as easy as clutching the tractor. An additional concept is that the moving tractor will also drive the PTO (at least to an overrunning clutch used for bushhogging) so letting the tractor stop befor shifting out is best. JimN
