Re: SERIAL NUMBER
Posted by CNKS on June 29, 2007 at 19:47:30 from (204.249.178.32):
In Reply to: SERIAL NUMBER posted by ELVIN C FRANK on June 29, 2007 at 19:12:12:
If it has a starting tank, or a hole in the right rear corner of the hood, A means it has a distillate engine, a little unusual for a Super M, but distillate engines were available through 450 production. J means it has a Rockford clutch, as nearly all of them do. The Super M has a high speed 4th standard. For the M, not the Super M, X1J means gasoline engine, high speed 4th, 5000 ft altitude pistons.
