Re: check out this m with duels!!!! only 750 in TX!!!
Posted by RustyFarmall on June 30, 2007 at 05:58:23 from (66.43.253.26):
In Reply to: check out this m with duels!!!! only 750 in TX!!! posted by jonnny2006 on June 30, 2007 at 00:13:00:
Looks like nothing more than an M with 2 sets of wheels and tires. If you slide the first tire/rim/center combination all the way in on the axle, there is room to mount a second set. The factory dual option used what basically amounted to 2 rims on one center, and a pair of quite narrow tires mounted on those rims.
