Re: IH666D Misses when Hot - Help
Posted by El Toro on June 30, 2007 at 13:50:47 from (205.188.116.73):
In Reply to: IH666D Misses when Hot - Help posted by Paul in WI on June 30, 2007 at 10:24:04:
You probably have some blockage in the fuel tank
as Scott suggested. Make sure its vented too.
If there's a shutoff valve at the fuel tank I would remove the fuel line while holding a clean container under it and see if there's a full stream of fuel running out. Hal
