Farmall Super C - Spark Problem
Posted by Dan(Mass) on June 30, 2007 at 17:14:10 from (66.189.97.61):
Farmall Super C with a spark problem.
I replaced the following: points, condensor, coil, plugs, plug wires, rotor,ignition switch and cap. And I get interemittent spark at the points. If I clean up the points with a file I will get one good spark. Any ideas out there?
By the way it has a distributor. I've check all wire connections and ground and all is good.
