Re: 560/M Center Castings?
Posted by D Slater on July 01, 2007 at 07:31:04 from (72.65.143.131):
In Reply to: 560/M Center Castings? posted by LittleMackinawFarmall on June 30, 2007 at 21:32:47:
Sure can,the 560 wheels are probably cast # 363014 R4 or R5. May interest you to know that in 1956 IH released a service package with that type wheel and rims for use on M,SM.SMTA and 400 with serial # 501 to 5180 tractors. Reason given to meet sales demand for a wheel with improved hub to axle mounting and to provide a easier means of tread adjustment by use of double beaded rim construction.
