Re: 560/M Center Castings?
Posted by Sagebrusher on July 01, 2007 at 11:58:09 from (69.19.14.41):
In Reply to: 560/M Center Castings? posted by LittleMackinawFarmall on June 30, 2007 at 21:32:47:
I'm a bit confused about where you are headed with the center casting swap and tires, rims, etc.
For what it is worth, I bought a set of Power Adjust wheels and rims with excellent condition chloride filled tires last winter that reportedly were from a 560. They had only the single key but were for a 2.75 inch axle just like my M. They bolted right up to the M.
The hardest it works anymore is with an eight foot blade and a nine foot disc. If the single key way held up to the 560's hp it should continue to do so on the old M.
