Re: On the 51 M's Should the serial number match?
Posted by Andy Motteberg on July 01, 2007 at 22:05:42 from (4.143.220.78):
In Reply to: On the 51 M's Should the serial number match? posted by jonnny2006 on July 01, 2007 at 19:01:37:
The number should match, or its not the original engine. The serial number on the tag on my H is FBH-133801 and the number on the engine is FBH-88099 and the casting codes on the engine and clutch do not match. If the engine & tag numbers match like they do on lots of our other tractors, it is the correct engine.
