M's Clutch shaft went south
Posted by LinemanFarmer on July 02, 2007 at 17:29:36 from (70.130.58.49):
I got that liftall pump out, you guys were right, that pump was heavy! But it come out with no problem at all. But after I got that out I think I got an idea of what happend. One of the bolts was loose on the U-joint and fell out, (nothing looks wrong with it) and the may have let that shaft torque one way and broke the release sleeve carrier and sheared a bolt that holds it to the case. I have not got it out yet, but that is all that it looks to be broke. Well I imagine I wont have much luck finding just that piece. So If you guys would happen to have one that I could purchase or know where I could get one along with the bearing, I would be very happy.
Thanks for the help, Derek
