Re: Any tool and die makers here?
Posted by Bob Kerr on July 03, 2007 at 07:35:26 from (64.12.117.8):
In Reply to: Re: Any tool and die makers here? posted by Rootsy on July 03, 2007 at 06:04:27:
It is the center part of the coupler from clutch to trans input flange. it is basicly a metal ring but has offsets. The taper bolts go through it and is cusioned with the rubber washers. I think almost everone with an old IH needs one, the holes get egg shaped and cause the shaft to wobble. H and M both use them , but different size and also I know F-12 uses them also, I am getting the idea almost all older IH tractors use them.
