Re: 350 Utility Hyd. Breather
Posted by Don Benson on July 03, 2007 at 16:14:32 from (71.98.210.67):
In Reply to: 350 Utility Hyd. Breather posted by Chris Schlossnagel on July 03, 2007 at 14:19:55:
The breather cap is just to keep water out and purge air from the system sounds more like you have a small hydraulic leak either in the cylinder or in the control valve itself. The best way to check is with a pressure gage. I had the same problem with mine
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
