Re: Touch control temperature range??????????
Posted by Gene-AL on July 04, 2007 at 07:30:58 from (74.226.19.205):
In Reply to: Touch control temperature range?????????? posted by Patrick Martin on July 03, 2007 at 21:08:34:
"Why is there a temp guage in the hydraulics anyway????? "
According to an original IH manual, to warn of possible high temperature damage to the hydraulic pump & seals in case the lift is blocked by something, such an an implement striking the bottom of the tractor before reaching the position called for by the control lever setting. This would cause the pump to run continuously at maximum pressure and overheat, according to IH.
On my SA the first 3/4 of the gauge is 'Run' and the upper fourth is labeled 'Hot'. I've never seen it move, so it's either defective or has never been very warm. The pump sound is quite obvious when it's working at high pressure.
