Re: sluggish govenors on an H
Posted by Slappy on July 04, 2007 at 18:08:21 from (65.0.152.176):
In Reply to: sluggish govenors on an H posted by Charlie M on July 04, 2007 at 15:34:57:
Check the linkage first - it's easy and the proceedure is in the owners manual. If you are certain that the linkage is OK and that nothing is binding, the two most likely causes are the spring (a new spring is the only fix) or the weight-pin-carrier assembly.
To check the latter, look to be sure that the pins are tight in the carrier (the weights rotate on the pins, the pins do not move in the carrier). If the pins are tight then it's a good bet that the pin holes in the weights are worn into egg shapes. You'll be amazed at what a big affect you get from only a little wear here.
You can still get pins and weights from the dealer, but you'll need a used or NOS part if the carrier is worn out. Although if the wear isn't too bad you might have a shop that can bore and bush the carrier.
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
