Re: International Cub died out
Posted by Bob on July 05, 2007 at 08:42:14 from (69.178.229.154):
In Reply to: International Cub died out posted by Davidcub on July 05, 2007 at 08:18:47:
Connect a test light between the coil's primary termainal that connects to the distributor, and ground, then crank the engine with the ignition "on".
The light should FLASH as the points open and close.
If the light stays ON all the time, there's an open circuit between the coil and points, or dirty points.
If the test light NEVER lights, there is a short in the primary circuit... distributor, points. condensor.
