International Cub died out
Posted by Davidcub on July 05, 2007 at 08:18:47 from (74.234.78.90):
Hi everyone,
I searched past posts and followed past advice but have still not had success with this problem.
My dad was drving his cub to the barn after cutting grass, and went to shift to 3rd gear and the tractor died out, and would not crank again. We checked, there was no spark at plugs, pulled the dist. points were pitted. We replaced points, replaced condenser, tested the coil(OK), tested voltage at + side of coil with key on(have 12v-OK, cleaned/checked connections, dist. shaft is turning, reassembled. Still no spark. Could there be something grounding in the distributor area? There is a little play in the shaft, if this is worn can it ground out something? Please help, thanks, david
