Re: International Cub died out
Posted by glennster on July 05, 2007 at 08:44:18 from (76.223.242.115):
In Reply to: International Cub died out posted by Davidcub on July 05, 2007 at 08:18:47:
if you have a 12v test light or ohm meter, pull the wire off the coil that goes to the distributor points, hook you test lite to the hot wire going to the coil and touch the probe to the wire going to the distributor, then crank the engine over, when the points are open the lite should go out. when the close, it should come back on. if the lite is on all the time, there is something grounding the points out, wire touching inside the distributor, maybe the insulator where the wire gos thru the distributor body.
Today's Featured Article - Harry Ferguson - The Man & The Machine Harry Ferguson was christened Henry George but every one called him Harry. Harry was born in a small Irish town called Growell in County Down about 16 miles from Belfast. Harry Ferguson led a varied and colorful childhood causing mischief where ever he could. He showed mechanical aptitude at a very early stage in life and showed no inclination towards ... [Read Article]
