Re: Super A troubles
Posted by old on July 05, 2007 at 14:56:54 from (4.244.6.20):
In Reply to: Super A troubles posted by za766 on July 05, 2007 at 14:38:00:
Gas to the carb but does it get into the carb as it should. Pull the drain plug out of the bottom of the carb and let it run for 5 minutes or so. Do you have a good steady flow of gas?? If you don't then you have some dirt/junk in the carb and it needs cleaned out. If it does flow well then pull the air intake tube off start it up and with it running put your hand over the carb and pull it off just before it dies. Do that a few times and see if that makes it run better. Thats a trick to pull dirt etc. out of the main jet and some times will fix that type of problem. You can also pull the main jet out if adjustable and spray carb cleaner into it with the drain plug out or if nonadjustable pull the mainjet plug and spray it out. Not likely to be the coil because if the coil is going bad it would have to sit for a couple hours before it would start again
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
