Re: 560 diesel fuel problems?
Posted by Larry in Mo on July 05, 2007 at 20:16:18 from (75.105.155.251):
In Reply to: 560 diesel fuel problems? posted by Bryan Ross on July 05, 2007 at 19:57:00:
Never had any experience with a 560, but all diesels have a procedure to bleed the air out of the system, any time the fuel supply is interupted. Open all of the bleed vents till you get a steady flow of fuel with no air bubbles. If fuel supply was fine before it should be ok now. If you don't have the proper procedure on bleeding the system find a manual or someone that has one. LE
