Re: 560 diesel fuel problems?
Posted by No tools on July 05, 2007 at 21:15:05 from (71.79.47.23):
In Reply to: 560 diesel fuel problems? posted by Bryan Ross on July 05, 2007 at 19:57:00:
No#1 cause is the return fuel line is probably plug or if rubber line as after market replacement line is restricked.
No#2 If that is not the case then you Roosa master pump has a bad flex plate crumbling inside the pump.The crumble pieces float around and plug return back to tank.Shuts the metering valve off.
The pump will have to be removed and recondictioned.
Bill
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
