Re: wiring lights on super c farmall
Posted by C-Man on July 06, 2007 at 05:10:53 from (69.77.252.108):
In Reply to: wiring lights on super c farmall posted by parisspringstom on July 05, 2007 at 19:02:50:
I just ran 2 wires from the switch. One for each light. I started with a small wire and was lucky enough to get it hooked with a small hook and then I pulled the larger wire through. I was able to put the small wire all the way through the "tube" and then I was able to use a small, but long, o-ring pick to pull it down the "post". Tie the wire you want to use on your lights to the small wire and it should pull around to corner of the "tube" and "post". I tried to take the set screws out of my Super C and they would not move. Good luck.
