Re: super c hydraulic problems
Posted by georgeky on July 06, 2007 at 08:08:04 from (205.188.116.73):
In Reply to: super c hydraulic problems posted by farmall 66 on July 06, 2007 at 06:51:42:
I think Jim is on the right track. If you look on the sides of your hydraulic unit you will see some Allen head bolts that look like plugs. These are for adjusting the stop clips. When they are not exactly right they allow the unit to keep trying to pull oil, which keeps the pump loaded as you mentioned. It may even be whining a little. If not adjusted properly it will cause system failure. A I&T manual has the adjustment procedure in it. This does need to be done by the book. Good luck.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
