Re: 560 diesel fuel problems?
Posted by Brownie450 on July 06, 2007 at 08:18:46 from (207.177.82.179):
In Reply to: 560 diesel fuel problems? posted by Bryan Ross on July 05, 2007 at 19:57:00:
WE had the same thing on our 560. Turned out to be a corn tassel that would float around in the tank until it lodged in the tank outlet. Of course, the 560 was used on the picker--which means lots of trash even with good housekeeping. Good news is--it was an easy fix. Bad news was--had to take the tank off to clean it.
