Re: Farmall 400 Diesel Engine Determining Engine Number
Posted by John-Paul on July 06, 2007 at 10:59:20 from (216.169.177.76):
In Reply to: Re: Farmall 400 Diesel Engine Determining Engine Number posted by John-Paul T on July 06, 2007 at 10:56:12:
BTW, I think your on the right path. For coolant and fuel to mix its gotta be head or headgasket. Maybe even block but lets hope not. Best would be a bad gasket. Im not sure if it could cause it but check the cylinder sleeves too, for any cracks etc. Least they arent too expensive.
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
