Re: Ordering piston rings
Posted by Owen Aaland on July 06, 2007 at 19:15:06 from (65.165.246.40):
In Reply to: Ordering piston rings posted by SDE on July 06, 2007 at 17:55:48:
If you go with a set of rings from the dealer you will probably get cast oil control rings. They work well when the sleeves are in good shape and give good service life. When I put rings into engines with used sleeves and pistons I perfer steel oil control rings which you will get from aftermarket suppliers. They seem to offer better oil control on less than perfect bores.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
