Re: cub clutch dont work
Posted by billde on July 07, 2007 at 05:54:58 from (72.26.87.225):
In Reply to: cub clutch dont work posted by super red on July 06, 2007 at 20:14:31:
Sounds like you may have broken the throwout bearing. The throwout is a composite. Do you have about 5/16 of black material on the front side of the metal retainer of the throwout? The proper adjustment is to have 1/8 clearance between the bearing and the clutch fingers.
You said the clutch pedal stayed down, does it have the return spring under the floorpan? Is the bearing free on the shaft?
