Re: 230 Fasthitch
Posted by georgeky on July 07, 2007 at 16:47:14 from (205.188.116.73):
In Reply to: Re: 230 Fasthitch posted by Dozinhal on July 07, 2007 at 13:01:25:
The pin I was talking about is underneath the hydraulic cylinder. It should have a little ring on it to pull it with. Just look at the bottom of it and you can see what I am talking about. It lets the hitch raise up on its on. The hand lever by your left leg is to adjust the amount of draft. This is IH's mechanical draft control. This time of year the ground may simply be to hard to get a plow in. I do suspect the pin removal will cure your trouble. Is your tractor spinning out before the plow gets in the ground good? If it doesn't work let us know and we might find a cure.
