Re: 460 clutch/TA question
Posted by Owen Aaland on July 09, 2007 at 00:35:06 from (65.165.246.40):
In Reply to: 460 clutch/TA question posted by School boy on July 08, 2007 at 20:29:42:
The main clutch disengages the transmission but the TA is really two clutches in one assembly. The front clutch, direct drive, is a dry disk clutch like the main clutch. The low side TA clutch is an overrunning style clutch that automatically engages when ever the TA direct drive cluch disengages and the tractor slows down. The TA assembly is a planetary drive type unit which uses the overrunning clutch to hold the planetary carrier from turning while in the TA position. The planetary gears supply the speed reduction. When the lever is moved forward, the TA direct drive clutch engages causing the overrunning clutch to release and the whole assembly turns as one unit. What happens when you try to shift if only the main clutch disengages and TA direct clutch does not, there is usually enough windup in the drive train to cause the transmission input shaft to turn backwards. This causes the TA overrunning clutch to lock up. With both TA clutches locked up th TA cannot turn backwards so the transmission gears are still under load. This makes it very difficult to get out of gear. To adjust the TA linkage first make sure the stop pin is on the slot in the bottom of the TA clutch handle. This is a pin that limits the travel to keep the lever from going to far forward. Remove the pin in the front of the main clutch adjusment clevis. Remove the connecting link and spring between the main clutch shaft and the TA cluch shaft. With the TA lever forward, adjust the linkage rod so that while holding the pin in the clevis forward, it will move about 3/16 inch back in the slot before the bearing touches the levers on the TA clutch cover. This establishes the TA clutch release bearing free travel. Next adjust the free travel on the main clutch rod so that you have one inch free travel in the clutch pedal when measured at the platform. Connect the spring between the Main clutch shaft and the TA clutch shaft. Adjust the connecting link between the two so that the pins just enter the clevis without having to move either shaft. Check the adjustment by operating the controls. When moving the TA lever to the rear, the TA clutch shaft must move as soon as the lever moves. With the TA lever forward, watch as you move the clutch pedal. The TA clutch shaft must move as soon as the pedal moves. Road test the adjustments by making sure the TA downshifts before the TA lever is is back far enough to engage the latch. Face the tractor uphill. With the transmission in low gear and the TA lever forward, make sure that the tractor will start roll backward when the clutch pedal is about 3/4 of the way depressed. With the clutch fully released, make sure the transmission can be shifted even if the tractor rolls backward a little. With the tractor in first gear, start to release the clutch. Let up a little on the brakes to find the point where the TA will lock up and the tractor stops rolling bacward. From this point, you should need to release the clutch a little more before the tractor starts to move forward. If the tractor starts to move before the TA locks up you will get a double shift wh
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
