Re: 400 Whats the Fix???
Posted by Janicholson on July 09, 2007 at 05:49:18 from (199.17.6.122):
In Reply to: 400 Whats the Fix??? posted by Short Bolt on July 09, 2007 at 03:40:10:
The Idle issues mentioned need only one thing added. If the tractor was just "kept running with light loads, or idling, it may be that getting it to idle down will not immediatly cure the problem. Running it under load for 20 hrs (not all at once) with modern oil, and fuel will probably be the next medicine. With ignition off, as City Boy indicates, it is preignition. Use fifth TA ahead to kill it as you shut off the key (after ideling for a minute to normalize temps. JimN
