400 Whats the Fix???
Posted by Short Bolt on July 09, 2007 at 03:40:10 from (69.21.20.90):
Bought a 400 farmall off a 92 year farmer. He told me how good it was, so I gave him $1500.00 cash took it home. Went and put it on the hay tedder, ran it about a hour went to shut it off, and it ran backward< Started it back up real quick tried to shut it down again same thing. Ended up putting it in gear and riding the brakes hard. to kill it.
Check the idle ,to fast took idle adjustment screw out all the way out and it still idles fast. Took all throttle linkage off still idles fast. Back the timing off till it runs bad. Then it will shut off.
Whats the fix????? Thanks
