Re: 500-C Crawler engine problem, Timing???
Posted by Janicholson on July 10, 2007 at 06:27:53 from (199.17.6.122):
In Reply to: Re: 500-C Crawler engine problem, Timing??? posted by Doug in Pa on July 09, 2007 at 17:39:11:
The valve cover needs to be pulled off, along with the injectors on all cylinders. The #1 cyl (away from operator (sorry for the obvious, no derision intended)) should be placed at TDC. This will either be on the top of the compression stroke, or the top of the exhaust stroke. Both valves should be closed if it is the top of the compression stroke. Both valves will (probably be nearly closed if it is the top of the exhaust stroke. Rotate the engine (by hand) in its correct direction watching the valves. If it was on TDC compression, both valves will stay closed until the crank is turned 180 degrees (or very close), then the exhaust valve will begin to open. From there, the exhaust valve will remain open until just before it reaches TDC again. If it was the TDC of the exhaust stroke, the intake valve will begin to open right away as the rotation begins, and it will stay open until near the end of the 180 degrees. Then the intake will close, and the compression stroke begins with both valves closed, on up through TDC for about 360 degrees. If this is checked, and found to be close, I would suspect the pump, or other issues with compression. The way it stopped is not like timing, it is like a fuel issue. However, if you can turn it by hand with the injectors in, the situation might be compression, Diesels are difficult to turn with a starter, and usually not by hand at all. The information I have given is generic, I am not framiliar with the 500C engine, and have no clue whether it has the Gas start, diesel run engine of the early series, or a diesel with pre heater, or with glow plugs. The diesel part of the valve cycle I have described is accurate and will tell the story of timing. Best of luck, and please let us know what happens with a new thread, and what turns out to be the cure. JimN
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
