Re: What is an I-6?
Posted by Haas on July 10, 2007 at 14:08:01 from (12.65.48.246):
In Reply to: What is an I-6? posted by Poooch on July 10, 2007 at 11:28:25:
I have an I-6. Some differences between it and the W-6. Narrower rear wheel tread, different transmission gears (high speed 4th and low speed 1st). Third gear is about the same as 4th on a normal M transmission. It also may have solid cast front wheel hubs, or it may have the normal spoke type cast hubs. Rear hubs will be solid cast hubs. They are very heavy, about 3 inchis thick where the rim mounts to the hubs and thicker at the center. Various hubs and tires were available, but most I-6's came with 24 or 26 inch size tires on the rear I believe. Mine has 24 inch rears. (14.9x24 as I recall which would have been the old 13X24 size). I think most W-6 tractors had 30 inch tires on the back. Also there were other options such as hydraulic brakes and a brake on the clutch to stop the transmission when the clutch was disengaged for easier shifting. The drawbar arrangement was also different than the W-6, the normal one being for a pintle hook ring. There may be other variations. Mine has a home made drawbar, as it was used as a farm tractor and the one that came on it was not suitable for farm implements.
